Batch E-transmit all models on Revit Server
Hi all,
With the end of support for Revit 2021 creeping up on me, i am starting to archive all revit projects on revit server, including all links, dwgs etc.
I have about 300 models that need to be E-Transmitted from the Revit server, which is an enormous amount of work to do manually.
Has anyone ever attempted at batch E-Transmitting? I’ve looked for a while now and haven’t seen an example just yet. Is there anyone who can nudge me in the right direction?
There isn’t a direct call as far as I know, but I believe you can achieve the required work with the transmission data class of the API.
There is the relatively undocumented RevitServerTool.exe usually located here C:\Program Files\Autodesk\Revit <year>\RevitServerToolCommand\RevitServerTool.exe
I have used it in the past to bulk download models off Revit Servers using a DOS batch file.
Some Autodesk info here Revit Server Model Creation Command-Line Utility
There’s this post Purge Unused and eTransmit for DA4R from Jeremy Tammik, however I don’t think there will be a straightforward solution
Additional info here
Thanks guys!
I’ll try my luck with your suggestions and update when i make some prgress…
It’s a bummer you can’t access the ETransmit directly. Creating a local file and also copying all linked files into the new folder is so handy for archiving models. Once projects are finished, we ETransmit a model to our archive, including all linked models/CAD files. Doing this for 140 projects though…
