Typical task for MEP models: we need to see Architectural and Structural models by “Linked views”. So, for each level we have one view in the linked model which should be associated with ALL floor plans on that level in our model.
We could do that using Archi-Lab node “Apply View Template”, but in this case we would overwrite ALL graphical settings, while we need to control only Revit links appearance.
To apply only settings which are not controlled by current view template we use View.ApplyViewTemplateParameters method instead of assigning a template by ID as it’s done in Konrad’s node.
So, the logic is quite straight forward:
we use regular view templates to control visibility settings of model elements without control of linked models
we create a separate set of templates which control only linked models and apply there settings we need
using modified node we apply to our views those templates without changing applied templates, just changing links appearance
Modified node is in the attachment:
Automatically Apply Settings from View Template
It uses a list of “Level-Required Template” pairs as the second input, which should be created externally.
I would be very great full!
