Hello everyone!, this is my first post here so apparently I can only upload one image and I have got a question about a script I made, the purpose of this script is to create View Filters, I attached an image of the Script, and it works fine with Instance Parameters, which is great but I’d also like it to work with Type Parameters, does anyone have a sugestion to fix this issue?
When I try to do the same thing with a Type Parameter, an error shows up “Object reference not set to an instance of an object” in the last two nodes, does anyone know if there’s a way around it?, a way to fix the script or maybe it has to be a different script for Type Parameters?
Thanks in advance!
