I am trying to change the parameter value of detail elements in Revit. I have done that using these nodes but when I work on big files where I have many other elements of the same category that method is not viable anymore. The problem is that the output value is an abstract name with a number. If I want to do the same in Revit manually I will have the axis to the properties of the elements and I can simply change the values by their name while here the value doesn’t show the value name. for example the graphic style output in this shot is a hidden line how can I know that ?? Any suggestions ??
