Automatic view generation Dynamo-Revit
Hi all,
I’m working on a script in dynamo to create automatic views in Revit2017.
Does anyone know if this is possible to make with Dynamo?
For example:
I want to generate all the window families into Dynamo and create 2 section views of each window.
Let me know if you can help me!=)
hello, maybe this link helps. use the node SectionView.ByBoundingBox . :slight_smile:
good luck
Hi Lars,
Maybe the workflow of @Dieter_Vermeulen can also point you in the right direction.
https://revitbeyondbim.wordpress.com/2017/02/10/element-view-generation-in-revit-with-dynamo-revised/
Ik hope it helps
Thanks for your reply!:slight_smile:
Thanks! I definitly will try this one!:slight_smile:
