Automatic Tag
Hi All i am trying to create tag for element,Output are not shown.please explaine me what is the wrong in this simple script.
Try this
Hi @Mike.Buttery ,Thanks for the reply
find the attached snap for your information. Still not getting output
You are missing too many inputs for the node to work.
View, leader etc etc…
I would think it should work with what you have…maybe check your tag and the element you are tagging is taggable in Revit as a test >>>>…
Hi if it a duct you will tag then try get a point on the location line as tag location…
Hi @Kai ,thanks for the solution.
Hi @sovitek ,
Thanks for the response let me try this script as well.
yeah if its ducts or line location based :wink: but seems to work now with @Kai solution, please mark his solution :wink: if it works…
