Automatic Grouping of Clashes in Navisworks
Can we automate clash grouping in Navisworks using Dynamo ? Lots of time could be saved if this could be possible .
Take a look at this article.
Thank You for response . I was looking forward using dynamo instead of add ins .
link to the plugin does not work, do you have any copy of it to be able to test? thanks
It’s this app, you can see it in the link name.
I would like to know more about the possibilities of naming the groups by that plugin, for example combining what is in selection A vs Selection B names, categories rather than what is the category name of the selection A clashing against the others.
I am not sure if its functionality is same as the Issues plugin of Autodesk BIM360 for Navisworks.
Haven’t used it before myself, sounds like a Navisworks based query for the forums - might need some API as well.
It not same, but you can research and custom again becuase group clash have open source
