Hello!
Want to create script for automatic bulckheads placement above doors. The idea is to select bulckhead family type than select door on the view.
That’s what I have now. Doesn’t work :(
Anyone can help me with the script?
Hello!
Do you want to manually select each door or would you want to do it for all doors?
Would this work for you?
With some small adjustments you should be able to get it working for all doors of the same family in one go as well
An alternative that’d probably be a bit better would be to get the door’s location and offsetting that by the height of the door, but I already did this, so…
