Automate add package name note above node
Hi there,
it’s a fairly basic question and I apologize if I’m missing out a simple one in Dynamo but… is there a way to add automatically notes with the package name and version of the nodes included in a dynamo graph (obviously not the ones OOTB)?
I did find datashapes do that as a menu command but what about to mark the others packages’ nodes?
Thanks in advance
Check out Monocle by @john_pierson, you should find it through the Packages menu.
Thank you @Bjorn_Keulemans1 lovely! thanks a lot!
Cheers
