What is the error I am trying to put the dimensions from the face of the column to the Grids but it gives me the dimension of the column
Hard to tell by the screenshot as you have errors on nodes and also Python scripts, but the outcome indicates your issue lies with the addition of grids to the lists of column references. Start there, and work your way back. Ideally all dimensions will have 3 references that should be parallel to the column faces. The List.Insert looks a bit off, I’d expect it to insert an item @L1 to a list @L2 usually.
Hey @Abdelrahman.Ahmed96, What your error is, is what I am trying to build.
I’m quite new with Dynamo and would love to learn different approaches to a problem.
Could you maybe share what you did in the script, because it is a bit hard to read?
Or, if possible, It would be great if you could share the script itself.
Hope to hear from you.
“Could you please share your Dynamo file with me?”
hello, i created dynamo script for automate dimensions, but i stucked in the last step, please review my file and feedback to me.
02. Auto Dim Columns.dyn (120.9 KB)
Better stick to your own topic and just follow the
these other ones.
Don’t ‘hijack’ other peoples topics ![]()
