Is there a node to attach top or base of wall to floor or ceiling?
This is not exposed in the Revit API, and as such Dynamo cannot create the parametric constraint.
As an alternative you can build the wall by sketch or edit the wall’s sketch to ensure the wall is limited to the geometry of the element you’d otherwise attach to.
