Assigning serial number to the pipe as water move in the pipe stream
Hey
I would like to give serial number to the pipe in increasing order as water is flowing in the pipes. As showing in the picture 401, 402, 403 etc
In T joint, it will assign the number in till the pipes end and then again start the numbering from T joint stream.
In the given example, number series start with respect to pipe diameter if 4" dia pipe start with 400 series and 3" dia pipe start with 300 series.
Thanks in Advance
@honeyjain619
I also needed the same idea, but I did not find a solution, so did you find a way to do that?
Hello, you have to try to look in this way to identify the branch of the network concerned (several possible paths) then associate the numbering
network connection points must be identified.
I think it’s not at all simple the work you want to undertake.
Cordially
christian.stan
I have resolve my problem using “Element in connected network” node from MEPover package.
and I am getting solution as mention in the sample file.
Hope this will give you, alternate approach to resolve your problem.
