Solve salesman problem, Shortest Path through Points, by using Python 3
I need to share
how to use Python3 to solve salesman problem, Shortest Path through Points,
Shortest Path.dyn (26.4 KB)
I use eploy Python genetic algorithm library as shown in the below link
import sys
import System
dirAppLoc = System.Environment.GetFolderPath(System.Environment.SpecialFolder.LocalApplicationData)
sys.path.append(dirAppLoc + r'\python-3.8.3-embed-amd64\Lib\site-packages')
clr.AddReference('System.Drawing')
import System.Drawing
from System.Drawing import *
from System.Drawing.Imaging import *
from System.IO import MemoryStream
import numpy as np
import matplotlib.pyplot as plt
from PIL import Image
import io
import math
import numpy as np
from scipy import spatial
def plt2arr(fig):
    need to draw if figure is not drawn yet
    fig.canvas.draw()
    rgba_buf = fig.canvas.buffer_rgba()
    (w,h) = fig.canvas.get_width_height()
    rgba_arr = np.frombuffer(rgba_buf, dtype=np.uint8).reshape((h,w,4))
    return rgba_arr
def convertToBitmap2(npImgArray):
    bitmap_ = None
    # remove alpha
    if npImgArray.ndim == 3 and npImgArray.shape[-1] == 4:
        npImgArray = npImgArray[:, :, :-1]
    # convert to PIL Image
    if npImgArray.ndim == 3:
        image = Image.fromarray(npImgArray, "RGB")
        image = Image.fromarray(npImgArray, "L")
    # convert to Python ByteArray
    byteIO = io.BytesIO()
    image.save(byteIO, format='BMP')
    byteArr = byteIO.getvalue()
    # convert to Net ByteArray
    netBytes = System.Array[System.Byte](byteArr)
    with MemoryStream(netBytes) as ms:
        bitmap_ = Bitmap(ms)
    return bitmap_
#num_points = 10
X=IN[0]
num_points=IN[1]
#points_coordinate = np.random.rand(num_points, 2)  # generate coordinate of points
#points_coordinate = np.array([[50 , 6],[100, 0.23430645],[0.26308841, 0.25977513],[53 , 600]])
#points_coordinate = np.array([[pt[0],pt[1]] for pt in IN[0]], dtype=np.float32)
points_coordinate = np.array([[pt.X, pt.Y] for pt in IN[0]], dtype=np.float32)
distance_matrix = spatial.distance.cdist(points_coordinate, points_coordinate, metric='euclidean')
def cal_total_distance(routine):
    '''The objective function. input routine, return total distance.
    cal_total_distance(np.arange(num_points))
    num_points, = routine.shape
    return sum([distance_matrix[routine[i % num_points], routine[(i + 1) % num_points]] for i in range(num_points)])
from sko.GA import GA_TSP
ga_tsp = GA_TSP(func=cal_total_distance, n_dim=num_points, size_pop=50, max_iter=5000, prob_mut=1)
best_points, best_distance = ga_tsp.run()
points_coordinate
fig, ax = plt.subplots(1, 2)
best_points_ = np.concatenate([best_points, [best_points[0]]])
best_points_
best_points_coordinate = points_coordinate[best_points_, :]
ax[0].plot(best_points_coordinate[:, 0], best_points_coordinate[:, 1], 'o-r')
ax[1].plot(ga_tsp.generation_best_Y)
plt.show()
image_from_plot = plt2arr(fig)
bitmap1 = convertToBitmap2(image_from_plot)
OUT = bitmap1,best_points_coordinate.tolist()
Hello RMohareb:
Do you know if there is a way to create the shortest path but with ortogonal angles only. Because i want to draw a pipe layout across few street blocks to connect some buildings and i want to design it with generative design to optimise the layout.
Hi @Rlucki
you can look to the AU class @Cesare_Caoduro3. He show how to fined the shortest path for the cable. i think it may be help you. see in 33:00 min in the class video
thank you so much, now i will apply these and adapt it to my problem.
i think that the problem with this algorithm is that we do not have cable trays on the model, there are just nodes that i want to connect with the shortest network possible and a starting point or a main branch with a starting point that needs to be included in the connection tree.
https://skieffer.info/publications/kieffer2016hola.pdf in this paper talks about creating connections between nodes
Awesome work @RMohareb ,
Have you tried different case with another algorithm? such as PSO/ Ant colony/ SOS?
I am currently working for this kind of technique to optimize BIM. Looking forward if you have done previous work/ reference to be followed :slight_smile:
now i am trying to learn more about python to achieve these task, it’s something that i still can’t resolve
