Automatic flow addition to Chilled water pipes
Revit has a default flow parameter to the terminal units where if the flow is added to the units it gets transferred to the pipes. Sometimes it is not possible or may produce wrong values due to some reasons:-
  1. If the connector flow settings in the families such as flow configuration, Loss method, etc are incorrect.
  2. If the connector flow setting in the pipe fitting is incorrect.
  3. Incorrect pipe accessories used.
  4. The cumulative flow in the pipes may not be accurate and to resolve this fittings have to be disconnected and connected again.
The script does the following:-
The video shows the automatic addition of flow from mechanical units to the pipes and pipe fittings. As shown there are 16 mechanical units connected in the network and each is assigned a flow of 0.5 L/s. The integrated flow is automatically added to the following pipes upstream and the sum flow in the end pipe is 8 L/s (16*0.5). The pipe and pipe fittings are set with the respective flows and there is nothing to be changed or edited to the families or fittings used in the project.
import math
clr.AddReference('DSCoreNodes')
from DSCore import *
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
# Import RevitAPI
clr.AddReference("RevitAPI")
from collections import defaultdict
# Enable Python support and load DesignScript library
import math
import sys
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Electrical import*
from DSCore.List import Flatten
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#for Using  C# List
import System
from System.Collections.Generic import*
import collections
app = uiapp.Application
if isinstance(IN[0],list):
	connector = UnwrapElement(IN[0])
	toggle = 0
	connector = [UnwrapElement(IN[0])]
	toggle = 1
bool = IN[1]
def nextElements(elem):
	listout = []
	if elem.GetType() == Connector:
		conn = elem
		for c in conn.AllRefs:
			if c.Owner.Id.Equals(elem.Owner.Id):
				continue
			elif isinstance(c.Owner,MEPSystem):
				continue
				newelem = c.Owner
			listout.append(newelem)
		return listout
	try:
		connectors = elem.ConnectorManager.Connectors
	except:
		connectors = elem.MEPModel.ConnectorManager.Connectors
	for conn in connectors:
			if c.Owner.Id.Equals(elem.Id):
				continue
				continue
			elif c.Owner.Id.Equals(ownerId):
				continue
				newelem = c.Owner
	return listout
def nextElementsWithOwner(elem):
	listout = []
		conn = elem
				continue
				continue
				newelem = c.Owner
		return listout
	try:
	except:
				continue
				continue
				newelem = c.Owner
	return listout
def collector(elem):
	cont = 0
	elements = nextElements(elem)
	for x in elements:
		if x.Id in lookup:
			cont += 1
			item = doc.GetElement(x.Id)
			lookup[x.Id] = item
			collector(x)
	if cont == len(elements):
		return elem
def collectorWithOwner(elem):
	cont = 0
	elements = nextElementsWithOwner(elem)
	for x in elements:
		if x.Id in lookup:
			cont += 1
			lookup[x.Id] = item
			collectorWithOwner(x)
		return elem
listout = []
if bool:
	for x in connector:
		lookup = collections.OrderedDict()
		listout.append(lookup.Values)
	for x in connector:
		if x.GetType() == Connector:
			ownerId = x.Owner.Id
			ownerId = x.Id
		collector(x)
if toggle:
	OUT = values = lookup.Values
	OUT = values = listout
#System classification rule filter
Sys_rule = ParameterFilterRuleFactory.CreateContainsRule(ElementId(-1140325),"Hydronic Supply",True)
#C list for filters
Filters = List[FilterRule]()
Filters.Add(Sys_rule)
# Parameter Filer
param_filter =ElementParameterFilter(Filters)
# Adding elements to csharp list
elementIds = List[ElementId]()
for value in values:
	elementIds.Add(value.Id)
# Filtering on the existing element list
Fec_Elements = FilteredElementCollector(doc,elementIds).WherePasses(param_filter).ToElements()
def Find_Connection_Between_Elements(All_Elements_Of_Category):
	p = []
	dir = []
	rep = []
	ref = []
	#elements = List.Flatten(elements,2)
	for e in All_Elements_Of_Category:
		refs = []
		try:
			connectors = e.MEPModel.ConnectorManager.Connectors
		except:
			connectors = e.ConnectorManager.Connectors
				connectortype = str(c.ConnectorType)
				if connectortype == "End":
					refs.append(c.Owner)
		ref.append(refs)
	return ref
def Find_Connectors(elementlist):
	if isinstance(elementlist, list):
		elements = elementlist
		toggle = 0
		toggle = 1
	listout = []
	for element in elements:
		try:
			connectors = element.MEPModel.ConnectorManager.Connectors
		except:
			try:
				connectors = element.ConnectorManager.Connectors
			except:
				connectors = []
		listout.append([x for x in connectors])
	if toggle:
		return listout
		return connectors
connected = Find_Connectors(Fec_Elements)
def Unwrap(item):
	return UnwrapElement(item)
def ProcessList(_func, _list):
    return map(lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list)
if isinstance(connected, list):
	connectors = ProcessList(Unwrap, connected)
	connectors = [Unwrap(connected)]
def IsConnected(connector):
	bool = False
	try:
		bool = connector.IsConnected
	except:
		pass
	return bool
booleans = ProcessList(IsConnected, connectors)
filtered_list = []
for c,b in zip(connected,booleans):
        filterted = []
        for a,d in zip(c,b):
            if d:
            	sys = a.MEPSystem.Name
            	if "CHWS" in sys:
                	filterted.append(a)
                	continue
        filtered_list.append(filterted)
def getConnSysType(connector):
	systype = None
	try:
		sys = connector.MEPSystem
		systype = doc.GetElement(sys.GetTypeId())
	except:
		pass
	return systype
def getAllRefs(connector):
	refs = None
	try:
		refs = [doc.GetElement(x.Owner.Id) for x in connector.AllRefs if x.Owner.Id != connector.Owner.Id and x.ConnectorType != ConnectorType.Logical]
	except:
		pass
	if type(refs)==list:
		if refs == []:
			return None
			return refs[0]
		return refs
def elementcategory(elements):
	elementlist = []
		categorylist = []
		for item in element:
			try:
				categorylist.append(item.Category.Name)
			except:
				categorylist.append(None)
		elementlist.append(categorylist)
	return elementlist
#connected_elements = Find_Connection_Between_Elements(Fec_Elements)
connected_elements  = ProcessList(getAllRefs,filtered_list)
for  elements in connected_elements:
	lg = len(elements)
	if lg ==1:
		dex = connected_elements.index(elements)
		ele = Fec_Elements[dex]
		ki = elements.insert(0,ele)
final = []
for connected_element in connected_elements:
	if len(connected_element)>1:
		final.append(connected_element)
elements_category = elementcategory(final)
for item,category in zip(final, elements_category):
	pos = elements_category.index(category)
	index_size = len(category)
	if index_size == 2:
		cont = category.count("Pipe Fittings")
		if cont ==2:
			del final[pos]
			del elements_category[pos]
			del Fec_Elements[pos]
		if f_e_name == "Pipe":
			continue
			type_id = f_e.GetTypeId()
			ele_type = doc.GetElement(type_id)
			ele_fam = ele_type.Family
			ele_name = ele_fam.Name
			if "Tee" in ele_name:
				fe_index = final_element.index(f_e)
				fe_insert = final_element[fe_index] = fec_element
final = []
def setvalues(list1):
	elements = []
	elementids = []
	idvalues = []
	for l1 in list1:
		list2=[]
		list3 = []
		list4 = []
		for el in l1:
			element = UnwrapElement(el)
			elementid = element.Id
			elementvalue = elementid.IntegerValue
			list2.append(element)
			list3.append(elementid)
			list4.append(elementvalue)
		elements.append(list2)
		elementids.append(list3)
		idvalues.append(list4)
	m=1
	length = len(elements)
	while m <length:
		rest = []
		for el,ids,val in zip(elements,elementids,idvalues):
			boolean = []
			empty = []
			indexes = []
			index_values =[]
			size = len(el)
			if size == 3:
				for j,k,l in zip(el,ids,val):
					param= j.LookupParameter("flow")
					param_value = param.AsDouble()
					if param_value==0:
						boolean.append(True)
						index = val.index(l)
						index_value = el[index].LookupParameter("flow").AsDouble()
						indexes.append(index)
						index_values.append(index_value)
						boolean.append(False)
				count = boolean.count(False)
				if count ==2:
					values = []
					for b,id,v,v1 in zip(boolean,indexes,index_values,el):
						if b==False:
							values.append(v)
							value = sum(values)
							n = id
					p_value = el[n].LookupParameter("flow").Set(value)
					rest.append(el)
				elif count ==1 or count==0:
					rest.append(el)
					continue
			elif size==2:
					if param_value==0:
				if count ==1:
					values = []
						if b==False:
							values.append(v)
							value = sum(values)
							n = id
					rest.append(el)
				elif count ==0:
					rest.append(el)
					continue
			elif size==4:
				for idx,j in enumerate(el):
					if param_value==0:
						index = idx
						index = idx
				if count ==1:
					values = []
						if b==False:
							values.append(v)
							value = v
							n = id
					rest.append(el)
				elif count ==0:
					rest.append(el)
					continue
			elif size==1:
				continue
		m = m+1
	return elements
setelements = setvalues(final)
cat_list = [BuiltInCategory.OST_PipeFitting, BuiltInCategory.OST_PipeAccessory]
typed_list = List[BuiltInCategory](cat_listdef elementcategory(elements):
	elementlist = []
		categorylist = []
			try:
			except:
	return elementlist)
filter = ElementMulticategoryFilter(typed_list)
#Catfilter = ElementCategoryFilter(ElementId(-2008049))
catlist = List[ElementId]()
for Fec_Element in Fec_Elements:
	catlist.Add(Fec_Element.Id)
Cat_Filtered= FilteredElementCollector(doc,catlist).WherePasses(filter).ToElements()
Cat_Filtered_connectors = Find_Connectors(Cat_Filtered)
Cat_Filtered_connected = ProcessList(getAllRefs,Cat_Filtered_connectors)
#for f,c in zip(Cat_Filtered,Cat_Filtered_connected):
for l1,l2 in zip(Fec_Elements,connected_elements):
    for l3 in l2:
        if l1.Id == l3.Id:
            l2.remove(l3)
	lg = len(elements)
	if lg ==1:
OUT = Fec_Elements,final
Hi Chandu
I have seen your post and i am very happy with your output , could you please attach the Dynamo script and/or a video.
I am facing a similar issue and it will be great to see your solution.
Regards
@CHANDU
tag
