Assigning Parametric Dimension Values using Excel
Hi Guys, I just started my journey with Dynamo and it has been pretty fun. However, I have encountered a roadblock.
I am trying to change the dimensions of my adaptive model using Excel. However, I have 10 instances of the same family type, each having their own unique Mark/ID. I want to only change one element.
For example, I want to change Element mark 1-1U 's wings to be 1500mm but Element Mark 1-2U to be 3000mm.
Is this possible? Any help will do thanks!..
The headings (Wings_A, Wings_B) corresponds to the adaptive values of the family itself.
If the parameters are instance parameters then you should be able to assign them individually with an Excel file
