#I’ve been able to assign a multiple parameters and parameter values to multiple elements, but only to one category (e.g. walls).
#Is there a way to combine nodes, or a python code to assign a parameter to multiple categories (e.g. walls, floors, columns) at once? See python script below with 4 inputs (0,1,2,3):
_paramName = IN[0][0]
_groupName = IN[0][1]
_paramType = IN[1]
_visible = IN[0][3]
_category = IN[2]
_paramGroup = IN[3]
_instance = IN[0][6]
#Python Script
'#Copyright© 2015, Konrad Sobon
'# @arch_laboratory, http://archi-lab.net
'# Import DocumentManager and TransactionManager
'# Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
'# Import ToDSType(bool) extension method
import System
'#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
_paramType = IN[1]
_visible = IN[0][3]
_category = IN[2]
_paramGroup = IN[3]
def ParamBindingExists(_doc, _paramName, _paramType):
map = doc.ParameterBindings
iterator = map.ForwardIterator()
iterator.Reset()
while iterator.MoveNext():
if iterator.Key != None and iterator.Key.Name == _paramName and iterator.Key.ParameterType == _paramType:
paramExists = True
break
paramExists = False
return paramExists
def RemoveParamBinding(_doc, _paramName, _paramType):
iterator.Reset()
definition = iterator.Key
break
message = None
if definition != None:
map.Remove(definition)
message = “Success”
return message
def addParam(doc, _paramName, _visible, _instance, _groupName, _paramGroup,k):
message = None
if ParamBindingExists(doc, _paramName, _paramType):
if not RemoveParamBinding(doc, _paramName, _paramType) == “Success”:
message = “Param Binding Not Removed Successfully”
message = None
group = file.Groups.get_Item(_groupName)
if group == None:
group = file.Groups.Create(_groupName)
if group.Definitions.Contains(group.Definitions.Item[_paramName]):
_def = group.Definitions.Item[_paramName]
_def = group.Definitions.Create(opt)
param = doc.ParameterBindings.Insert(_def, bind, _paramGroup)
return message
'#“Start” the transaction
try:
file = app.OpenSharedParameterFile()
except:
message = “No Shared Parameter file found.”
pass
k=0
while k<_paramName.Count:
builtInCategory = System.Enum.ToObject(BuiltInCategory, _category[k].Id)
cats = app.Create.NewCategorySet()
cats.Insert(doc.Settings.Categories.get_Item(builtInCategory))
if _instance[k] == “true”:
bind = app.Create.NewInstanceBinding(cats)
bind = app.Create.NewTypeBinding(cats)
opt = ExternalDefinitionCreationOptions(_paramName[k], _paramType[k])#Revit 2015 Fehler “ExternalDefinit[ i ]onCreationOptions”
opt.Visible = _visible[k]
if isinstance(_paramName[k], list):
for i in _paramName[k]:
message = addParam(doc, i, _visible[k], _instance[k], _groupName[k], _paramGroup[k], k)
message = addParam(doc, _paramName[k], _visible[k], _instance[k], _groupName[k], _paramGroup[k],k)
k=k+1
'#“End” the transaction
#Assign your output to the OUT variable
if message == None:
OUT = “Success”
OUT = message
