Hey everybody,
I am trying to set the categories to which a parameter can have a value , ie these:
For testing purposes I created two parameters, a shared one and a standard project one:
Both are temporarily assigned to only one category:
I then tried running this script:
clr.AddReference('System')
clr.AddReference('RevitAPI')
app = uiapp.Application
params = UnwrapElement(IN[0])
TransactionManager.Instance.EnsureInTransaction(doc) #necessary?
bindings = doc.ParameterBindings
#Create a Categoryset containing all model categories
modcats=sorted([i for i in doc.Settings.Categories if i.AllowsBoundParameters])
allcats=CategorySet()
for cat in modcats:
allcats.Insert(cat)
#Modify and update parameters
for param in params:
paramdef = param.GetDefinition()
item = bindings.Item[paramdef]
item.Categories=allcats
bindings.ReInsert(paramdef,item)
doc.Regenerate() #necessary?
TransactionManager.Instance.TransactionTaskDone()#necessary?
OUT = 0
On the shared parameter it works with no problems:
But on the project parameter it does nothing and no errors appear. If i read the binding’s Categories with python it shows me all of them, but in the Revit UI I can’t see any change (neither in elements or in the project parameter window)
It’s like as if the binding won’t update completely. What else could I try other than bindings.ReInsert , doc.Regenerate, transactions…?
