Hi all,
I am trying to assign values for mark parameter of column elements from a list 1. I have a list of elements to be marked in list 2. But I have only 13 elements in list 2 and 15 values in list 1. I want to assign corresponding values as shown in image. Kindly let me know how to do that ?
I want to skip the values where the element is eliminated. If I have equal lengths of lists then it will work fine for me but if I have unequal then I am facing problems. Final output I want is as marked in the image
Thanks in advance
@shashank.baganeACM can you show you’re script?
Are the elements that are eliminated still available in dynamo?
I think python can help you.
Hi @jw.vanasselt sure. Here are the script and revit files. Please let me know how I can use python to solve my problems
Column numbering.rvt (3.1 MB)
Multi story Structural Column Numbering.dyn (104.3 KB)
Thanks for the documents.
This is you’re problem:
What you need to do is find the elements that you are eliminate.
After that you can do something like this:
Thanks @jw.vanasselt but I somehow manage to find the elements which are eliminated represented as “empty list”. I have values now. please refer below image.
Now I want assign the respective values to corresponding elements. What ever you have posted the python code it doesnot work for me. Can you please check where I am missing ?
values = IN[0]
ele = IN[1]
newvalue = []
for i in values:
if i == "Empty List":
newvalue.append("empty value")
newvalue.append(values)
Can you share you’re script again?
And can you give me for example you’re inputs?
BTW, values is i
Here it is I have updated the script. Please find it below
Multi story Structural Column Numbering.dyn (156.1 KB)
What are you’re inputs here?
@jw.vanasselt
irst input 1 = I will select the top level of column present like if I am having column upto 8th floor level then I’ll select 8th floor level
Second input = To extract the values, I will give the Parameter name
(for example “Mark”)
Third input = I will give for upper level elements to be marked, start with “1F-” its a string.
When I check you’re last script you can feed those elements in the rythm node right?
And the values, or do I miss something?
Hi @jw.vanasselt I have got the solution without using python.
here is the logic I have used
Thanks for your time. I really appreciate your support.
Good job! Glad I could help!
