Wish all good for you.
I have a problem regarding my script that I have 2 main task here
First task to duplicated Sheet complete with View. This task have finished as per shown below.
The Second task, I want the View that already duplicated to use the other View templates
I try to follow some node but not sure how to go as I am still newbie on the Dynamo.
Hi, there is a node in Archilab package called SetViewTemplate, I’ve used it in similar Dynamo Script as you are trying to do.
Since this is a Script from 3 years ago, I havent really updated it.
But I used something like this to select Viewtemplates for differenc Drawing Types.
The second statement correct mate : “will the duplicated views be assigned a different view template?”
How I connect my the Duplicate Sheet Script to yours picture?
I just thinking once I run the Duplicate Sheet Script as per picture below.
The warning on View.ApplyViewTemplate should explain what’s going on. You should have also gotten a dialog when you placed that node as it has invalid input names. You just need to edit the custom node and change the inputs to a valid name (not an existing class) and everything should work again.
