ArkanceSystem - Create Table
I am using the AutoCADTable.CreateTable node from ArkanceSystems. It works great besides it not letting me draw the table in a layout. It draws it in model space with no problems if I have nothing going to the “layout” section. See snip. Thanks!
Check the input for ”Layot”. What does it ask for? I think it’s Layot as in table layout. (Not at my computer and able to test)
You need a Layout object, the dropdown is only returning strings. In the Layout group there is something like Get by Name node which must be used in between.
Anton, I cant seem to find it. Every options is ether a string or block. Do you know the precise node name?
I’ll have a look later, don’t have a computer right now.
This is the node:
Layout.GetLayoutByName
This is the result:
