When you get the Area boundary lines they might not be a closed boundary since Areas can deal with that.
Any idea how to close the missing segments?
This should work assuming all your room bounds are straight:
- Extract the endpoints of all the curves
- Extract the startpoint of the first curve and insert it at the start of the point list
- Create a new polygon from the point list using
Polygon.ByPointList()
Thanks Thomas, that’s what i ended up doing
