Are anyone able to export IFC using Dynamo in Revit 2027?
Been testing and converting scripts to 2027 and the only ones I can’t get to work are the ones relating to IFC-export. Neither fetching custom IFC setups or exporting an IFC works though the pathways python scripts have used in the past.
Has anyone been able to crack this?
Could you share some code?
The oldest one I use is this, it has a ton of inputs:
Export with settings
clr.AddReference(“RevitAPI”)
import os
def tolist(obj1):
if hasattr(obj1,“_iter_”): return obj1
else: return [obj1]
app = uiapp.Application
Inputs
folder = UnwrapElement(IN[0])
view = tolist(UnwrapElement(IN[1]))
name = tolist(UnwrapElement(IN[2]))
fileversion = IN[3]
Projectorigin = IN[4]
inputPhase = UnwrapElement(IN[5])
userDefinedPset = IN[6]
revitInternalPset = IN[7]
wallandcolumnsplitting = IN[8]
exportbasequantities = IN[9]
categoryMappingPath = IN[10]
tessellation = IN[11]
Valider at kategori-mappingfilen finnes
if categoryMappingPath != “” and not os.path.exists(categoryMappingPath):
OUT = “Feil: Kategori-mappingfilen finnes ikke:\n{}”.format(categoryMappingPath)
if inputPhase:
phaseString = str(inputPhase.Id)
userDefPsetBool = "true" if userDefinedPset != "" else "false"
revitInternalPset = "true" if revitInternalPset else "false"
result = \[\]
for i, v in enumerate(view):
    options = IFCExportOptions()
    # IFC versjon
    versionMap = {
        "IFC4": IFCVersion.IFC4,
        "IFC4RV": IFCVersion.IFC4RV,
        "IFC4DTV": IFCVersion.IFC4DTV,
        "IFC2x2": IFCVersion.IFC2x2,
        "IFC2x3": IFCVersion.IFC2x3,
        "IFC2x3CV2": IFCVersion.IFC2x3CV2,
        "IFC2x3BFM": IFCVersion.IFC2x3BFM,
        "IFC2x3FM": IFCVersion.IFC2x3FM,
        "IFCBCA": IFCVersion.IFCBCA,
        "IFCCOBIE": IFCVersion.IFCCOBIE
    options.FileVersion = versionMap.get(fileversion, IFCVersion.Default)
    options.WallAndColumnSplitting = wallandcolumnsplitting
    options.FilterViewId = v.Id
    if inputPhase:
        options.AddOption("ActivePhase", phaseString)
    options.AddOption("SitePlacement", Projectorigin)
    options.AddOption("SpaceBoundaries ", "0")
    # Innhold
    options.AddOption("Export2DElements", "false")
    options.AddOption("ExportRoomsInView", "false")
    options.AddOption("VisibleElementsOfCurrentView", "true")
    options.AddOption("ExportLinkedFiles", "false")
    # Property Sets
    options.ExportBaseQuantities = exportbasequantities
    options.AddOption("ExportInternalRevitPropertySets", revitInternalPset)
    options.AddOption("ExportIFCCommonPropertySets", "false")
    options.AddOption("ExportSchedulesAsPsets", "false")
    options.AddOption("ExportSpecificSchedules", "false")
    options.AddOption("ExportUserDefinedPsets", userDefPsetBool)
    if userDefinedPset != "":
        options.AddOption("ExportUserDefinedPsetsFileName", userDefinedPset)
    # Kategori-mappingfil
    if categoryMappingPath != "":
        options.AddOption("IFCCategoryMappingTable", categoryMappingPath)
    # Avanserte innstillinger
    options.AddOption("Use2DRoomBoundaryForVolume ", "false")
    options.AddOption("UseFamilyAndTypeNameForReference ", "false")
    options.AddOption("ExportPartsAsBuildingElements", "false")
    options.AddOption("ExportBoundingBox", "false")
    options.AddOption("ExportSolidModelRep", "true")
    options.AddOption("StoreIFCGUID", "true")
    options.AddOption("UseActiveViewGeometry", "false")
    options.AddOption("IncludeSiteElevation", "true")
    options.AddOption("ExportAnnotations ", "true")
    options.AddOption("TessellationLevelOfDetail", tessellation)
    # Eksport
    c = doc.Export(folder, name\[i\], options)
    result.append(c)
OUT = result if fileversion != "" else "Default settings used"
And then one which fetches custom IFC export setups:
Got it from this post.
Presets (which it can't load)
import sys
import System
Import RevitAPI
from Autodesk.Revit.Attributes import *
from Autodesk.Revit.DB.IFC import *
sdkNumber = int(app.VersionNumber)
IFCExportConfiguration = None
IFCExportConfigurationsMap = None
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
pf_data_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.CommonApplicationData)
ifc_bundle_path = “{0}\\Autodesk\\ApplicationPlugins\\IFC {1}.bundle\\Contents\\{1}”.format(pf_data_path, sdkNumber)
if System.IO.Directory.Exists(ifc_bundle_path):
# 1st try
sys.path.append(ifc_bundle_path)
clr.AddReference(“IFCExporterUIOverride”)
from BIM.IFC.Export.UI import IFCExportConfigurationsMap, IFCExportConfiguration, IFCCommandOverrideApplication
ifc_addin_path = “{}\\Autodesk\\Revit {}\\AddIns\\IFCExporterUI”.format(pf_path, sdkNumber)
if System.IO.Directory.Exists(ifc_addin_path):
# 2nd try
sys.path.append(ifc_addin_path)
clr.AddReference(“Autodesk.IFC.Export.UI”)
import json
ifc_dict_config = {}
if IFCExportConfigurationsMap is not None:
# Always bind TheDocument to the current Revit document
propinfo = clr.GetClrType(IFCCommandOverrideApplication).GetProperty(‘TheDocument’)
propinfo.SetValue(None, doc)
configurationsMap = IFCExportConfigurationsMap()
configurationsMap.AddBuiltInConfigurations()
configurationsMap.AddSavedConfigurations()
for config in configurationsMap.Values:
    # print(config.GetType())  # if you need debug
    ifc_dict_config\[config.Name\] = config
OUT = ifc_dict_config
If I make an export script as short and simple as possible:
Short script
from Autodesk.Revit.DB import IFCExportOptions
opts = IFCExportOptions()
OUT = doc.Export(
r"C:\bench",
“TEST.ifc”,
opts
In any case I am given the message:
“PythonEvaluator.Evaluate operation failed.
Exception has been thrown by the target of an invocation.”
There have been changes to the revit-ifc API, notably some namespace changes; I haven’t had a chance to look into the details yet.
you can find the source code here
Resource
Good, I can retrieve setups now using this.
code
clr.AddReference(“RevitAPIIFC”)
from Revit.IFC.Export.Utility import IFCExportConfigurationsMap
configMap = IFCExportConfigurationsMap(doc)
configMap.AddBuiltInConfigurations()
configMap.AddSavedConfigurations(None)
OUT = {c.Name: c for c in configMap.Values}
However exporting IFC still eludes me.
simple export lines
OUT = doc.Export(“C:\bench”, “testing123.ifc”, opts)
Path should be "C:\\bench"
From the docs:
Exporting to IFC requires that document is modifiable, therefore there must be a transaction already open when this method is called
You have to wrap doc.Export inside a transaction
Note: use IronPython3 [worked], I found PythonNet3 would hang Revit until it crashed
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import ElementId, IFCExportOptions
ifc_opts = IFCExportOptions()
ifc_opts.FilterViewId = ElementId(IN[0].Id)
OUT = doc.Export("C:\\temp", "ifc_test", ifc_opts)
Crashing has been my other problem. I have installed IronPython3 now and can run the basic export script successfully with that. Guess I will stick to Iron for now and maybe try again in a future update.
Here’s a workaround using .Net Reflection for PythonNet3
current_doc.GetType().InvokeMember("Export", BindingFlags.InvokeMethod , None, current_doc, (pathfolder, name, options) )
full python code for Export
import sys
import System
clr.AddReference("System.Reflection")
from System.Reflection import BindingFlags
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
# Import RevitAPI
from Autodesk.Revit.Attributes import*
from Autodesk.Revit.DB.IFC import*
ifc_bundle_path = "{0}\\Autodesk\\ApplicationPlugins\\IFC {1}.bundle\\Contents\\{1}".format(pf_data_path, sdkNumber)
    print("pass1")
    if sdkNumber < 2027:
        clr.AddReference("IFCExporterUIOverride")
        clr.AddReference("Revit.IFC.Export")
        from Revit.IFC.Export.Utility import IFCExportConfigurationsMap, IFCExportConfiguration
        clr.AddReference("Revit.IFC.Common")
        from Revit.IFC.Common.Extensions import IFCClassificationMgr
        from BIM.IFC.Export.UI import IFCCommandOverrideApplication
    ifc_addin_path = "{}\\Autodesk\\Revit {}\\AddIns\IFCExporterUI".format(pf_path, sdkNumber)
        print("pass2")
        clr.AddReference("Autodesk.IFC.Export.UI")
def exportIfc(current_doc, pathfolder, name, ifcExportConfig, view3DId=ElementId.InvalidElementId):
    global error
    if name.endswith(".rvt"):
        name = name.replace(".rvt", ".ifc")
    #When using transactions with documents other than the primary document,better luck creating transactions from scratch.
    TransactionManager.Instance.ForceCloseTransaction()
    # define options
    if ifcExportConfig is not None :
        #Define the of a 3d view to export
        # copy settings of the myIFCExportConfiguration to the IFCExportOptions
            exportViewId = ElementId.InvalidElementId # or None -> add view in options
            ifcExportConfig.UpdateOptions(options, exportViewId)
            # Revit 2027 and above
            if view3DId == ElementId.InvalidElementId:
                ifcExportConfig.UseActiveViewGeometry = False
                ifcExportConfig.VisibleElementsOfCurrentView = False
                ifcExportConfig.VisibleElementsOfCurrentView = True
                ifcExportConfig.ActiveViewId = view3DId
            if ifcExportConfig.ExportUserDefinedPsets:
                userDefinedPsetsFileName = System.IO.Path.GetFileName(ifcExportConfig.ExportUserDefinedPsetsFileName)
                ifcExportConfig.ExportUserDefinedPsetsFileName = System.IO.Path.Combine(pathfolder, userDefinedPsetsFileName)
                userDefinedParameterMappingFileName = System.IO.Path.GetFileName(ifcExportConfig.ExportUserDefinedParameterMappingFileName)
                ifcExportConfig.ExportUserDefinedParameterMappingFileName = System.IO.Path.Combine(pathfolder, userDefinedParameterMappingFileName)
            ifcExportConfig.UpdateOptions(current_doc, options, view3DId, False)
            # call this before the Export IFC transaction starts, as it has its own transaction.
            IFCClassificationMgr.DeleteObsoleteSchemas(current_doc)
    t = Transaction(current_doc, 'Export IFC')
    t.Start()
    failureOptions = t.GetFailureHandlingOptions()
    failureOptions.SetClearAfterRollback(False)
    t.SetFailureHandlingOptions(failureOptions)
    try:
        current_doc.Regenerate()
        result = current_doc.GetType().InvokeMember("Export", BindingFlags.InvokeMethod , None, current_doc, (pathfolder, name, options) )
    except Exception as ex:
        print(ex)
        t.RollBack()
        t.Dispose()
        return 0
        t.RollBack() # instead of t.Dispose()
        t.Dispose()
        return pathfolder + '\\' + name
ifc_config_map = IN[0]
pathfolder = IN[1]
name = IN[2]
ifc_config_name = IN[3]
ifcExportConfig = ifc_config_map[ifc_config_name]
exportIfc(doc, pathfolder, name, ifcExportConfig)
