I am new to dynamo. I downloaded archilab but it wont show up in Dynamo. I am using Dynamo 1.3.4.0 with revit 2018. Archilab will show up under my installed packaged but not under my library. I have read several threads about unblocking and deleting stuff. I have tried all of that and ended up having to re-install all of my revit programs because i apparently deleted something i shouldnt have. Can anyone help me?
@tysong2461 It is showing up as Grimshaw if you take a closer look at your Library. But I believe that is not the package you are looking for (you installed archLIB instead of archiLAB).
archilab is hosted under the name archi-lab.net so try installing the correct package and it should show up as in the image below.
