Archi_Lab not installed in 2022
not able to install Konrad (2022.210.1022) in Revit 2022
You will need to uninstall archi-lab 2024.217.1024, this will most likely require you to restart Revit before re-installing the correct version.
If this is not working close Revit and manually delete the package and proceed with the re-install.
The default folder location for packages is C:\Users\<username>\AppData\Roaming\Dynamo\Dynamo Revit\<Dynamo version>\packages
