I created a script in Dynamo 2.10 (Revit 22), which lists out all linked dwgs, their paths and which view are they placed on.
I used archi-lab’s Elements.OwnerView block to get the view names, but it puts out ‘null’ if I run it in Dynamo 2.13 (Revit 23).
It works perfectly in Revit 22.
Any ideas why this might be happening?
turns out, it depends on how you linked your CAD files in your project. Element.OwnerView only gives you a value if you go to the INSERT tab → Link CAD → Tick Current View Only.
Otherwise, you can use Element.GetParameterValueByName to get the Work Plane value.
