So i’m just starting out with using Dynamo with Revit, and i’ve stumbled into a problem I’m unable to solve.
I’ve created a little bit of code that sets a parameter to have a number (Mark), and the idea is that it will then go through and add all the appropriate tags for that item (I.e Number Tag, Electrical Socket Tags, Water Connection Tags).
Now this works great using the Orchid node at applying the first tag, however it will not apply the second one no matter what. I know the code works when plugged into the element tag individually, however it won’t run both at the same time.
Am I making a very obvious and silly error here, or is their another sort of method I need to use to apply multiple tags?
Well that’s a bit silly of me, I took an image from when I hadn’t got everything connected up correctly! Even with the nodes correctly hooked up this still does not work. It’s almost as if it only runs the first set of nodes it runs into, but not the second set.
The whole MarkVariable() bit is just some redundant code at this point, it will eventually be used further down the line where I will need to know the number. It worked and didn’t seem to break anything so I just kept it in for now.
Yes the second Family Type is a tag (We’re not very good at naming our things correctly here!)
Just for the purposes of testing I swapped both to be the same tag and ran it. As you can see it was happy enough to run through the second Tag.ByElementAndLocation node, but did not like the first one.
If I remove all the connections to the second Tag.ByElement, then reattach it will run through the first instance but not the second, giving the same info in the watch nodes.
Here I was paranoid I was either calling the second set of commands incorrectly, or had butchered the logic somewhere, when in reality it was a bug in Orchid! I never would have guessed that correctly
Thanks for all yours, and everyone else who has replieds help!
