Apply Selection to Revit
Hi Forum,
I am trying to apply a selection in Revit.
actually i want to do the opposite of what the “Select Model Elements” Node does.
The idea is the following: i use dynamo to create a list with all the elements that are of interest with several Filter By Boolean Mask. An then i need them to be selected in Revit to apply a “selection Box” (BX) on them.
Is there anything like this available
thanks in advance
Jeff
Element.SelectInView node
try this:
I think you should add which package you’re using in that code.
Right, Springs.SelectInRevit is from “Spr…” :wink:
Well that was fast!
thanks a lot, it worked!
