Filtered selection Back to Revit
Good day everyone,
i have made a dynamo script to filter selection based on parameter value, i need to return the filtered selection back to revit . is there any node or code to do that ? i have searched for it with no luck
thanks
Hi @khuzaimah.ElecEng
You can use “Springs.Select inRevit” node.
@khuzaimah.ElecEng
Springs.SelectInRevit will add the filtered elements to your selection.
hello @Kulkul
not that what i mean,
i mean to return the selection to revit environment, something like built-in filter that on Revit
thanks @john_pierson , yes that is what i need
yes @Kulkul,
that’s solves my problem, thanks :slight_smile:
which node belong to which package?
You need to install the springs nodes packages
