I’m trying to apply a scope box to specific views. Actually, in the end it would be nice to be able to have all my views to automatically get scope boxes applied to them. Also, I need the script to also turn off the “Crop Region Visible” parameter as well. I have gotten to the very end of this. But, its shooting back NULL at me with no results. Any direction would be great. Attached the dyn file. APPLY VIEW TEMPLATES TO VIEWS.dyn (12.3 KB)
If your Revit parameter is a YES/NO parameter (infered by your use of false), you need to input an integer, not a boolean. In Revit it uses 0 = False, any other integer = True. If this is the case, set the value to 0 and it should work. The other issue, at a guess, is possibly caused by a View Template assigned to your active view.
EDIT: True and False will also work! There’s only one error to resolve…
What view are you using?
I only used ActiveView as an example. You need to pass the correct view into SetParameterByName. I’m guessing you’re active view can’t take a scope box.
The first SetParameterByName sets the scope box, the second one turns off the crop region.
(Added): it turns out that when you modify the sketch of your crop region, the Scope Box parameter becomes read-only. This is why some views return the “null” values.
I’m trying to apply the “Area A” scope box to all dependent views that have “Dependent 1” in the view name and turn off the “Crop Region Visible” parameter for the views. Everything works great until the first “Element.SetParameterByName” node.
Gah, new job linked to my autodesk account! Not right! Oh well, lol
I’m working on setting some scope boxes as well, but on my Element.SetParameterByName, I keep getting “Parameter Storage Type” is not a string when I try to write my Scope box names to the “Scope Box” parameter, not sure why as the examples above are doing the same thing.
So this works for me… kind of. It lists all 4 views I am trying to select correctly. But it only lets me select one scope box from the list and it makes all selected views that scope box. What I really need is Area A to be applied to the FINISH - Area A plan, Area B to be applied to the FINISH - Area B plan and so on.
Create a Dictionary: keys = strings [“A”,“B”,“C”,“D”]. values = your 4 scope boxes.
Get your views. Get the last character in the view name. Get Dictionary Value by Key, feed those characters into the Key. Assign the resulting Scope Box to the views.
