Apply Room Name & Number from linked model to Furniture
thank you so much @e1uvs :wink:
I’m getting a null value in Room.FinishBoundary but it still works
I’m getting wrong room numbers. And there are cases wherein there are more than 1 room in a room…
I am sorry for the late reply. Been swamped at work. I will be writing back to you to help out very soon.
Hello there. @e1uvs
Did you get it to work?
I copied the rooms from the link to the working file, using Michael Kilkellys script. I am using a little more simplified script to add the parameter(will be added below). With it I just add a “Room Name” project parameter as text and try to apply the script to it. I need it for el fixtures but I tried it with furniture as well, tried also running it in the architect model file but whatever I try I get this error… (curve joined produced more than one wire in PolyCurve…
Oh and on top of it all, I get a successful run only for 2 items. I don’t see a difference between those 2 items and all the rest.
I’m sure it’s a small mistake in my code but I can’t figure it out, I’m still quite new to visual coding.
Could someone assist me?
Room names On Elements 27.08.2019.dyn (40.1 KB)
Update:
Found this article
Works like a charm (with little adjustments ofc)
That is pretty much how I got it to work.
Thanks for this
