Hi everybody,
I have a problem with Dynamo. When I’m reopening an old script it appears with all the nodes condensed in the same place.
Did I mess up something or is this a problem with version or… don’t know.
Someone had the same problem and found the solution?
Thx in advance
Hi e.cietto,
Its for easier viewing when your script gets large, now its all compactly placed together
more seriously, this seems to be occuring for more users when using certain addons All Nodes on top of each other - #58 by ariderAEE99
I’ll check immediately, thx MVE1112
I don’t know why this happens, but as a quick solution, maybe you can select the nodes, right click and drlrvy “create group”. Then right click on the group and press “Cleanup Node Layout”.
PauLtus perfect,
this is what I needed being, as always, in rush.
Thank you
You’re welcome!
I’m always a bit surprised how well Dynamo manages to automatically organise these.
Definitely, this was a tool I didn’t even know about.
Grab your Revit journal and check for API_Error lines. Shortly before and/or after those lines should be the Revit add-in which is causing the issue in question.
Note that not all conflicts are an issue, and it may take a combination of multiple add-ins to cause the problem, but those erroring add-ins are the root cause every time I’ve seen this.
