I’m trying to find how to get all elements (walls and poles in particular) in a filled region.
Someone know if it’s possible ?
Thanks,
Alexis
Why not do it with rooms ?
Should be way easier i think or does it have to be with a filled region ?
Because there are already rooms defined in this region… I think it’s not possible no ?
It’s a grouping of rooms.
I dont understand you ?
If im right you are trying to get the info of the 2 rooms in the top left? Why would u do this with a filled region when you can just get all the elements in the 2 rooms which is way easier in my opinion
Filled regions are tough, as they are flat - that is they love in two dimensional space that is layered atop the three dimensional model.
An area may be easier, I think you can ask if a Point is inside an area. Plus they schedule, tag, and have all sorts of other benefits. Archilab has a Select.GetRoomAtPoint which means that you can likely build a similar node for spaces and areas.
Could you switch to using areas instead? ![]()
I found the tutorial of creating a filled region tag that gives the Area, and I am successfully created one, now I want it to bring it in schedule, I was wondering if you have dynamo script for that. Thanks.
