"All element in View" Node do not retrieve Tag elements?
How to get All Tag elements (Room tag, Ceiling tag, Door tag not Text tag) in specific view?
Hello @Jin Could you show your graph where your are stock
Like this one?
Yes! Room tag is worked but the others are not.
clockwork package and Data-Shapes package
You can choose other tag category if you want,by the way,the post by stefan can do the same thing.
I understand that other packages can do.
I just wonder why these things are not in default set up of dynamo or if there is any default ways to get this result without external packages.
The nodes I‘ve used in post are all out of the box nodes.
you would have to use the setup John used and copy it for each tag you want to get if you dont want external packages.
would use external pakages if i where you less of a pain.
