Hello experts:
Is it possible to assign Z Value to my 3D text model since alignment or profile information?
any ideas? what nodes should i add?
Note: i already got the model text since alignment as you may see in the top image
thanks for your responses
Hi @will.hermoza,
Try the Profile.ElevationByStation node. Or you could use the Profile.CoordinateSystemByStation node instead of getting the coordinate systems from the alignment.
This is a similar script I updated (the original script was found on the web, created by Patrick Ericson)
Thanks!!! I will try it right now!!! lets hope it works!
@LasmaDzintare Great! It worked not exactly as the image above which its kind of complex, but it gave me the main idea of how to solve this issue!
