I would like to ask whether there is a way to create a script that generates station elevation profiles, as shown below, for multiple alignments.
You could look to utilise creating a label set within the alignment edit station labels.
In the above example, a ‘TEST’ label set group was created which contains the Major station label for Profile elevation.
Script below takes all selected alignments and applies this label set group (ensure the Camber package is installed)
Hopefully this helps!
Cheers
Dylan
I think this will always be an issue, because alignments usually have more than one profile ( for example, Surface profile and Designed profile) - how would Dynamo choose which profile to use for each alignment? Or maybe you only have one profile for each alignment?
I’m assuming the simple scenario that we have only one profile for each alignment (design profile), however it can be filtered if we have multiple profiles for each alignment.
any updates?
Hello, in order to insert elevations at specific alignment stations, you first need to determine the coordinates.
I am sharing the graph with you. It requires:
The interval at which the data will be inserted.
A prefix for the design profile.
Please note that if you have multiple design profiles within the same Profile View, it may cause an error.
The justification of the text to be inserted.
The text height, according to your needs.
INSERTA TEXT EN PLANTA.dyn (44.3 KB)
