Hello everyone, I’m trying to align my general notes and keynotes consistently on the right side of the sheet, where they are typically placed. I’d also like to have an offset between the two. Keep in mind that both are schedules with different sizes.have you guys have see some script or dynamo routine for that?
Ohh yeah thank you, but the difference with schedules is that they aren’t viewports, so you have to approach aligning them in other ways.
¨Hi @Henrique-nandi you could try this one here
Thanks for that Sovitek. My plan was to run a script where my schedules (General Notes/Keynotes) are aligned based on the sheet’s coordinates. My schedules would always have the same X coordinate, and for the General Notes (schedule)at the top, the Y coordinate would be constant. The Keynotes(schedule) would be placed below with a variable Y depending on the size of the General Notes. To make this work, I believe we need to capture the start and end points of the General Notes. This was the approach I tried, but I wasn’t very successful.
arhh allright
if i understand right…you could try get the schedules boundingbox so you know the size of the schedule
