Greetings Dynamo Community,
Mode Lab has released a course on advanced topics in Dynamo: http://modelab.is/advanced-dynamo-curriculum/
This was an interesting project for us, and we look forward to developing more on the Dynamo front. Stay tuned for more!
Great tutorials. Thanks for sharing.
But I am unable to open the dataset for the tutorial with my Revit 2014…would any one know what the problem is?
I had the same issue I think, was it the error saying it was created in a later version? I upgraded to Revit 2015 and they open just fine.
I’ve been having trouble with Unit 2: Family by Point. My Surface.PointAtParameter isn’t generating a grid even when I check for cross product lacing, I just get a single cyan point at 0,0. This is when using the downloaded datasets for the tutorial so it cant be a mistake I’ve made? I’ve tried restarting, is there any known bugs/errors with this part of the tutorial?
I have attached Watch nodes to the Code Block and all appears to be working fine there, the U and V values are getting generated correctly. It just seems to be the Surface.PointAtParameter node that isn’t working
Simon, thank you for pointing that out. This appears to have been caused by a change in the “Select Face” node, which returns an array instead of a single item. I’ve filed a bug report internally to fix this (MAGN-5080).
In the meantime, you can fix it by using a “List.FirstItem” node to pick out the one item from the list containing one item.
Here’s the updated dyn file: Part-02-Family-By-Point.dyn
