I am new to Dynamo and trying to create my first script. It works fine as it is, but there are 2 extra points in the background and I just can’t work out why. Can anyone have a look and advise. File attached below. Thanks in advance.
I doubt you’re doing anything wrong.
Items in Dynamo can be rotated/ moved etc but the originals remain.
If you don’t turn off preview as you go then your canvas will be littered with points/ lines / curves etc.
Quick way to find out which node(s) are producing them is to drag a window over the nodes. When the background points turn blue you’ve highlighted the node(s) responsible.
