Luckily someone in the following forum post has shared the code within the “group_curves” node in the following forum post: Extracting closed Polycurves from given Surface - #2 by Mohammad_Nawar
I was able to get it to work in my script, so I finally have joined polycurves that I am able to offset. However, I need a way to filter a polycurve that is contained within any polycurve that exists in a list. This is so letters like A and P only offset the exterior lines, not interior.
TextHalo.dyn (16.3 KB)
#Copyright(c) 2015, Konrad Sobon
dataEnteringNode = IN
inputCurves = IN[0]
#join/group curves function
def groupCurves(Line_List):
ignore_distance = 0.1 # Assume points this close or closer to each other are touching
Grouped_Lines = []
Queue = set()
while Line_List:
Shape = []
Queue.add(Line_List.pop()) # Move a line from the Line_List to our queue
while Queue:
Current_Line = Queue.pop()
Shape.append(Current_Line)
for Potential_Match in Line_List:
Points = (Potential_Match.StartPoint, Potential_Match.EndPoint)
for P1 in Points:
for P2 in (Current_Line.StartPoint, Current_Line.EndPoint):
distance = P1.DistanceTo(P2)
if distance <= ignore_distance:
Queue.add(Potential_Match)
Line_List = [item for item in Line_List if item not in Queue]
Grouped_Lines.append(Shape)
return Grouped_Lines
OUT = groupCurves(inputCurves)
