I’ve succeeded in adding a single subassembly to a single assembly. But i would like to do it multiple times at once. I can’t seem to find a solution for this:
I hope someone could help me.
Hi @sven.deleau,
It should just be a matter of getting the list levels and lacing right. Is the second image the desired result, or something you’ve already achieved?
Hi @mzjensen,
The right image is the result of adding the subassembly.
the red lines(assemblies) stands for the DSN_1, DSN_2, DSN_3:
Only 1 works. what i tried to show in the image is that lacing doesn’t seem to be the problem.
I tried adding a subassembly independently 3 times in a row and that doesn’t work. If that works i wanted to put it into a single node with the correct lacing.
Hope this makes it a little bit more clear
OK I see what you mean. Unfortunately I think there’s an issue with the Assembly.AddSubassembly node.
Once a subassembly has been “consumed” it cannot be reused, you need to create new copies of the subassembly for each assembly
Is this possible by nodes or should i do it manually?
you can do it with the nodes but the subassemblies need to have different names
So i need to put a lot of different SubAssemblies into my enu/… folder?
Because manually you can add a subassembly with the same name, or is it something in the background with a different ID?
