Assembly.dwg (810.7 KB)
Hi all ,
am trying to create script to create assembly with subassemblies (same subassembly but different link code) , also adding offset assembly in-between
I did one assembly manually and exported assembly parameters to excel sheet
and tried to import them again but the subassemblies come in the same location as overlapping.
I tried to follow the same solution by @david_licona in below link of his reply
Assembly parameters.xlsx (9.1 KB)
