Adding multiple Elevation target in Civil 3D corridor using dynamo
I was trying to create a dynamo script using dynamo and Civil3D Toolkit to add multiple elevation target for a particular baseline region. I have created list containing the Profiles which need to be targeted to the baseline region but it is being targeted to only to the last object in the list and all the other objects are getting rejected without adding as elevation target.
I think you need to compare all the profile elevations based on the ‘Selection choice if multiple’ option.
Could you please attach the .dyn script so I can take a look at it?
