Add parameter to families in project
I have some families in my project generated by Enscape, so these families only excist in the project and are not stored somewhere.
I want to add some extra parameters to these families, i know i can do it through projectparameters, but i don’t want to add parameters there to keep it clean… and they also don’t need to be shared parameters.
I ‘just’ want to add a parameter.
You’ll need to either edit/open from project, and then load back to project, or save them out to a directory, open via filepath, add parameters, close/save then reload them.
The orchid package can do either route, but the second method is far easier. I have a video showing it here:
As far as I know theyre the simplest approaches short of using project parameters as you identified.
If you want to explore option 1, I shared a script here that shows how it can be achieved using python:
Elaborated solution posted here for searchability. OP also requested family based parmeters instead of shared.
Load and add family param.dyn (26.2 KB)
this is great… exactly what i needed… thanks a lot…
