hi, i’ve been trying this workflow for dynamo to add shared parameters to a family document.
For general text parameters worked fine, but it`s seen i can’t find the appropriete built in parameter for general number.
can someone help me on this ?
PARAMETROS ADD.dyn (48.7 KB)
PARAMETROS CONSULT.xlsx (19.9 KB)
im using “Data” Sheet
Parametros_Consult.txt (2.3 KB)
i need the built in parameter for this parameter type… what is it ?
Number.dyn (1.8 KB)
cant find built in parameter with this node. Actually, the node adding parameters just need BUILTINP
SharedParams2020.xlsx (15.0 KB)
thank you bro ! long life
