Add insulation problem in Revit 2024
Hi, I like to share my experience in dynamo , The above nodes script for adding insulation, it works in revit 2022 with respected to dynamo version and Mep over package. The Elements of ducts and pipes and pipes are filtered by level, system, prevent insulation overlap and thickness by if else condition.
This Element.AddInsulation node in MepOver is not working properly in revit 2024 (Mep Over version is 2024.9.25 ), and I also try some python script but no use, Kindly help me to fix it ,
Hello @ahammedfarsinmp guess you will need the right python package installed for 2024 it should be iron python 2.7 version 2.5 and can be installed from Pmanager
@sovitek thanks for your valuable information.
I gotit ,have a nice day
