Hi everyone,
I am trying to automate adding pipe insulation using Dynamo in Revit 2026, but I’m having trouble with the Element.AddInsulation node.
Goal
Automatically add insulation to selected pipe elements.
You’re going to find the that MEPover node may not work as intended or have limited functionality
Here is some python which will work with Revit 2026 (tested on all versions of python)
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import (
BuiltInCategory,
ElementId,
InsulationLiningBase,
SpecTypeId,
UnitUtils,
from Autodesk.Revit.DB.Plumbing import PipeInsulation
from Autodesk.Revit.DB.Mechanical import DuctInsulation
units = doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
PIPE_CATS = [
BuiltInCategory.OST_PipeCurves,
BuiltInCategory.OST_PipeFitting,
BuiltInCategory.OST_PipeAccessory,
DUCT_CATS = [
BuiltInCategory.OST_DuctCurves,
BuiltInCategory.OST_DuctFitting,
BuiltInCategory.OST_DuctAccessory,
def to_list(item, func=lambda x: x):
if isinstance(item, list):
return [func(i) for i in item]
return [func(item)]
def add_insulation(element, insultype, size, mep_type):
insul_ids = InsulationLiningBase.GetInsulationIds(doc, element.Id)
# Insulation has to be deleted before applying another
if len(insul_ids) > 0:
doc.Delete(List[ElementId](insul_ids))
mep_type.Create(doc, element.Id, insultype.Id, size)
pipes = to_list(IN[0], UnwrapElement)
insultype = to_list(IN[1], UnwrapElement)
size = to_list(IN[2])
size = list(map(lambda s: UnitUtils.ConvertToInternalUnits(s, units), size))
num_insultype = len(insultype)
num_sizes = len(size)
output = dict()
for i, pipe in enumerate(pipes):
size_idx = i % num_sizes
insul_idx = i % num_insultype
mep_type = None
bic = pipe.Category.BuiltInCategory
if bic in PIPE_CATS:
mep_type = PipeInsulation
if bic in DUCT_CATS:
mep_type = DuctInsulation
if mep_type:
add_insulation(pipe, insultype[insul_idx], size[size_idx], mep_type)
output.setdefault("success", []).append(pipe)
output.setdefault("failed", []).append(pipe)
OUT = output
