hello all
I have a situation here that I want to deal with it and I need your help
I have many types of floors and I turned them into a model group
I want to add this group into a coordinated points that imported from excel sheet
I can’t make it with dynamo
I made with only an element, how can i make it with a group model
could you help me with this
thank you in advance
the node is weard from clockwork…
when you open it. you get roof as input… i am not sure whats wrong
clr.AddReference('RevitAPI')
def AddPointToSlabShape(item, point):
if hasattr(item, "SlabShapeEditor") and hasattr(point, "ToXyz"):
try:
item.SlabShapeEditor.DrawPoint(point.ToXyz())
return True
except: return False
else: return False
items = UnwrapElement(IN[1])
if isinstance(IN[1], list):
if isinstance(IN[0], list):
OUT = []
for item, points in zip(items, IN[0]):
if isinstance(points, list): OUT.append((item, [AddPointToSlabShape(item, x) for x in points]))
else: OUT.append((item, AddPointToSlabShape(item, points)))
else: OUT = [(x, AddPointToSlabShape(x, IN[0])) for x in items]
OUT = map(list, zip(*OUT))
if isinstance(IN[0], list): OUT = items, [AddPointToSlabShape(items, x) for x in IN[0]]
else: OUT = items, AddPointToSlabShape(items, IN[0])
KR
Andreas
