Add elevation to points created from alignment
Hello, I have a query, will there be a way to add the elevation of the terrain to the points created from an alignment
You should be able to get the terrain elevation using the Surface.ElevationByXY and then set the elevation using the Civil 3D Toolkit :
@david_licona Thank
