Hi everyone,
I use the orchid pkg to Add or Create shared parameter with this two nodes:
I have no problem using them, with data from dynamo itself or importing from excel.
My questions are essentyaly two;
is there any way, in case the shared parameter is a text parameter to select “value can vary by group istance” (see following image)
when a new parameter is created with the node “Parameter.AddSharedParameter” is there the possibility yo compile the description field?
thanks for any tips or idea you can share with me
