Hello, Dynamo novice here.
I am trying to add shared parameters into my shared parameter file using Dynamo; as I have to add 45 and might have to do it again at some point. I am doing it according ABG (Gavin’s) tutorial on it.
As seen from the picture; after list transpose the data amount drops to 1/4, it is only collecting the data from list 3. I tried finding the solution from the forum to no avail. I have tried changing the the orchid node to a different one, but have come to the conclusion that the error is between the List.Transpose and the Code Block. Any suggestions are welcome.
Unfortunately the tutorial is old and i havent got this workflow/node to work for a while. Suggest dropping an issue on the orchid github if you cant get latest to work.
